Which transponders to set up Western Arc?
rvvaquero
3,482
4,777
SE Texas
When pointing the 1000.4 Western Arc dish, I was told to use 119 on transponder 13 or 21. Which transponders should I use for 110 and 129?
Thanks in advance for the help.
I personally use 21 for all three
Peek out the 129 for best possible signal as it will be about ten "points" lower then 110,119 which around here is normal.
For 110/119 use 14/15/16/21 and for 129 use 19/20/29/30. You want 65+ for 110/119 and 45+ for 129. I peaked my dish (1000.2) and got 85-90 on 119, 75-80 on 110, 65-70 on 129.
Thanks. Those are good numbers. What part of Earth are you located on?
1000.2 mounting question
Tap190506
