I've looked up & down on the forum for a few days & couldn't find my exact needs so here it goes.
I'm located at zip 70552. Tvfool has me at LOS 127° from my first signal to my right to my last signal to my left. My longest good (green) signal is 40 miles out. I have a Winegard amplified omnidirectional antenna in the attic which is approximately 15 feet above the outside ground that splits into four tv's averaging 20 feet of cable per tv. Channels I catch are hit or miss on average clear days, pixelation & lost signals are the norm. Thought about trying to amplify the signal, but amplifying a weak signal is still weak. Also, installing the antenna outside is a no go. No obstructions as I can tell & seasonal tree foliage seems not a factor due to problems not being seasonal. I haven't measured the signal due to the fact that I believe the experts here could tell me if my setup needs some additional equipment or a totally different setup is necessary.
Which setup would do best in my situation?
First:
CM-4221HD (180° multi directional should work for a 127° signal spread)
RCA TVPRAMP1Z or CM-7777HD
CM3414
Second:
Two RCA or equivalent yagi (to cover the 127° signal spread)
CM-0500
Two RCA TVPRAMP1Z or two CM-7777HD
CM3414
From what I've read here, omnidirectional is not the best signal catcher for my situation. I just want the proper equipment for the job. Any help will be greatly appreciated.
First:
CM3414
Second:
CM-0500
CM3414
