Which is bad - LNB or Switch?
Stacy A
1,248
northeast Texas
What are the symptoms of a bad LNB - old legacy on a Dish 300 pointed at 61.5. And, what would the symptoms be of a bad SW21 switch.
The evening before Hurricane Rita hit, when the winds picked up the first thing I lost was my 61.5. I assumed the wind had turned the dish, which is the most logical starting point, but using same elevation and azimuth (which we scribed on the dish with "line-up" marks when we originally pointed it) I don't even get a weak signal. I get a screen that says satellite has been lost. Going to the point dish/signal strength screen I get absolute 0 on all TP's.
So, which is the most likely culprit here? the LNB, Switch, or still a poor re-peak job?
The only way to know is to start eliminating pieces of the puzzle.
Run the 61.5 straight to a receiver and see if that makes a difference.
Note that with Legacy equipment, it's a bit harder to tell what's what when aiming. It would be good if you had a cheap beeper or meter to see if the LNB is actually doing anything.
Do you get Conn 110 Conn 119 Conn 61.5 with X's for Polarity? Or do you get Conn with 8 X's? If it detects the satellites by number, it's most likely a bad signal from a poor aligned dish or a bad LNB. A bad switch is easier to detect than a bad LNB, in my opinion. We get way more bad switches than LNBF's.
Yes, it shows 110, 119, and 61.5 with both odd and even polarities, but I thought that was going to on there until I ran another check switch - at which time I would likely lose the 61.5, if it had no signal from it.
By the way, would it interfere with a switch if you didn't mount it on a hard surface, but sort of electrician taped it to a live piece of underground romex as it was on its way to the breaker box?
Do the check switch because the receiver stores the last known switch configuration. It won't automatically do a check switch for you and tell you its status. So you have to run it through and see what it tells you.
new reciever
New install - signal strength?
