I am looking for ribbon cable to hook up my actuator to asc1. The cable I have is falling short for permanent routing. I looked on ebay and other online sources but wasn't able to find anything
I have a shielded 18/2 wire which I can double up and use. Wasn't sure if 18 AWG would be enough for power wires over 50ft.No ribbon cable sold any longer. You can use sprinkler wire for the motor and shielded security system wires for the sensor. You do not want the sensor and motor wires in the same shield. Motor noise can affect sensor signals.
18 AWG is probably too thin for the motor. I would suggest 14 gauge, maybe you can get by with 16 since it's only 50 ft, but not 18 gauge. A good choice would be landscape wire (sold for low-voltage landscape lights), or maybe speaker wire (but stay away from the aluminum wires)I have a shielded 18/2 wire which I can double up and use. Wasn't sure if 18 AWG would be enough for power wires over 50ft.
Doubling up 18 AWG conductors effectively gives you 15 AWG.I have a shielded 18/2 wire which I can double up and use. Wasn't sure if 18 AWG would be enough for power wires over 50ft.
