I purchased a 10' mesh dish, C-Band LNB, and an actuator (probably not working) today for $75 total.
The only location in my backyard where my wife says I can put it is in the corner. My neighbor has some trees spaced about 20 feet apart that will limit my line of sight of the southern sky to about 15 degrees horizontally.
I need to decide where exactly in the corner of the yard to place the thing, and where I put it will determine which satellites I will be able to get.
So my question is, which C-Band satellites do you guys aim at the most? Which ones have the most channels and are the most interesting?
I'm in California (approx 120 degrees longitude), so I could probably locate the dish to get a 15 degree range of birds somewhere between about 90W and 150W. For example, depending on where I put the pole, I will be able to get 90W to 105W, or 105W to 120W, or 120W to 135W, etc. I hope this makes sense.
I appreciate any input you guys have, thanks.
Brett
Brett
