uh yeah you might want to do thatMaybe I have to unplug the receiver instead off just using the swith in the back.
heck, that was my very first tip in "the tip of the iceberg"
http://www.satelliteguys.us/showthread.php?t=66143
Iceberg said:uh yeah you might want to do that
Ice, do you plan on adding to the tip of the iceberg from time to time?Iceberg said:heck, that was my very first tip in "the tip of the iceberg"
PSB said:Just checked my Traxis DBS 3500, when I turn the switch off on the back of the receiver no voltage is coming out of the "LNB IN"
I would unplug as a precaution when working with a DiSEqC switch, also other receiver may be different.
Keith Brannen said:O.K., let me get this straight... My Pansat 3500SD has an AC power switch at the back of the unit. Does this not completely power down the unit (certainly stops the clock!) and stop all voltage to the LNBs?
Or is it also better, as an added precaution, to unplug the unit as well?
I might. I had an idea to add the simple "FTA 101 most asked questions" in the tip but after a month I started running out of easy things. Yes there are lots of questions that are asked a few times but I didnt consider them simple "101" tips. So I kinda let the thread dieGary Z said:Ice, do you plan on adding to the tip of the iceberg from time to time?
I was looking at the NWA website, aren't you the wrestler Iceberg?
Iceberg said:the switch on the back kills all power. I always flip the switch off when adding/removing the line
cuongvu said:Hi all,
Where to place the Inline amplifier(before or ater the DisEqc switch)?
I have had bad luck with the 4x1 switches. 1 Sadoun switch (DOA), 1 Geopro (lasted 2 days) and 1 Coolsat(DOA) both from Sattelite Av (they are free), 1 cheap one from Ebay (DOA). The 2nd cheap one has been good so far (1 week).
Waitting for the 2 DMS International ones. If they are not good, that means something is wrong with my 4 years old Satcruiser+. Maybe I have to unplug the receiver instead off just using the swith in the back.
Cuong
iafirebuff said:3 million! That's alot of FTA'ers! Or can they be used for something else?
Keith Brannen said:Thanks for the idea! I checked my Pansat 3500SD, and there is also no voltage out of the IF INPUT when shut off at the back. Which is a very good thing (and a relief), considering how much I had added and changed configurations of LNBs and various switches over the past few months!
Just installed 2 DMS switches and 2 Amp (unpluged the receiver). They work.
I am very happy. Something was wrong with my 4 years old Satcruiser+ (or something was wrong with me ))))))
