What to do with 'skew'?
acuevas
SatelliteGuys Guru
132
Orange County
Hi All,
Concernign skew and dish pointing. When aiming a dish to one sat only. Is this a matter on EL & AZ as the only settings needed? when I look up the settings I also get skew. I thought skew was only used when trying to hit more than one sat?
It's the opposite.
This is regarding Linear Sats, not Circular.
When using a Motorized Dish, the LNB skew would be Zero when facing the True South Sat. As the Dish turns, the LNBF will be properly skewed.
When using a fixed Dish, you must skew the LNBF.
Someone will be along shortly to help you with skew. ;)
Just want to point out that you'll get a lot more exposure if you post one forum up. You're in a sub-forum for PC DVB cards. It's not exactly where you want to be.
PBS HD channel on AMC21
AZ Box Question
