> More importantly - do not cut cost on connectors. Get the bestr you can afford.
What would you recommend for connectors. I want to do this right the first and not have to revisit. Especially considering I am burying everything in the ground.
Here's the ones I use, not a problem with them so far:
PPC EX6 EX6XL RG6 Compression Fittings
Your connectors won't be buried , I wouldn't think-so don't worry about that. Just wrap them up with coax-seal and they will last a long time.
I got mine at Lowes Building supply too, like Dishman Dan. I don't know the model# of it, its not close to me at the moment to check, but it has blue handles, haha. And it works very well, one of the few tools I ever bought that I haven't managed to break or bend.
That's good info about the BNC connectors too, have to see if the one I have can be changed to do those.
...Which reminds me, I have to get another 500' roll of RG6.
turbosat;2635438 PPC EX6 EX6XL RG6 Compression Fittings[/QUOTE said:yep, that's the ones I use for compression f-connectors.
App note - don't use them if you are going to be connecting/disconnecting a coax tons of times. I have like 10 LNBs going into about 3-4 receivers so I have a setup much like an old telephone company (grin). I can connect and disconnect the various LNB lines to various receivers. I changed everything to the EX6XL compression connectors when I got the connectors and compression installation tool. After about 30-50 connects/disconnects, something funky happens around the butt end of the connector and you get an incomplete ground circuit so the receiver won't be able to tune the LNB input. I have redone those connect/disconnects back to crimp-style connectors because they are extremely robust (hundreds of connects/disconnects without an issue yet!) and I use the compression connnectors for those connections I plan not to touch more than 5-10 times (my more permanent connections).
