What in the world am I doing wrong?
Pepper
DVR Addict~Mad Scientist
8,354
1,310
Satsuma, AL
I have a ChannelMaster 3040842-02 1.0M-02 (the huge round one - 43 inches high by 40 inches wide). Using the stock feedhorn and a new dual-feed standard LNB. I've tried it on 97W, 99W, and 103W.
This dish is giving me fits. Pointed at the same satellite, a SuperDish (24 inches high by 33.5 inches wide) will consistently provide higher signal levels (around 20-25% more) than the ChannelMaster. I would think, all other things being equal, my signal with this big dish should be a lot better than what I am getting, and certainly should be a lot more than what I can get with a smaller dish.
I've checked everything I can think of. No obstructions, good cables, good LNB that works just fine when attached to a different dish. As far as I can tell, it's not bent or warped (how could it be, molded fiberglass would more likely be cracked and broken than bent)
Before I pull the rest of my hair out, any suggestions?
ChannelMaster (right) gets consistently lower signal than the SuperDish right next to it.
Ok, LOOK at the lnb feed. You have it strapped by the feedhorn, YET, it should be strapped closer to the lnb where the GROOVES are... So, move the face of it closer to the dish, and put the groove area in the saddle. I circled it in red below
Reactions: comfortably_numb
I do believe I have tried that and the position in that photo is where it gets the best signal. It's also where it actually fits. The top piece to hold it in place has always been missing, thus the zip-ties, but it fits exactly in that spot based on the size of the bottom piece which it sits on.
I will definitely fiddle with it some more though. I will also disassemble it all and take some better close-up pictures from multiple angles.
Perhaps I'm mis-remembering now. It's been many years. Anyway, here's the manual, that should help.
  • channel-master-type-120.pdf
Thanks for that. According to Figure 3.0 "Feed Assembly" it looks like I have it assembled correctly. Parts 11, 12, 13 are missing, replaced with zip-ties ;)
I'm thinking the wireties aren't enough support for that long and heavy feed, That's maybe allowing the whole thing to tilt slightly down in the back from the weight, which would screw with the focal point/face lifting slightly. Even just a hair might be enough to put the signal down 25%.
Get a piece of aluminum strapping, and make a new top part of the clamp, and clamp it down tight. Aluminum should be stronger, yet soft enough to hacksaw and files, etc whatever you need to make it work well. Or a U clamp that fits. Short of that, you could use a piece of plywood and cut it to fit the reverse of the saddle using a hole saw with your drill.
A few things not mentioned that may help. I helped a Brit get his same dish setup. It took a bit but eventually he "got it".
The LNBF. How rigid is it on the dish? Is the "look angle" correct? The LNBF needs to be set to see signals reflected 22.5 degrees off of the face of the dish. More on that if you need info.
Being an offset dish. You may be better off skewing it more like your other dishes. Or not.
LNBF placement rigidity is super important. As is aiming it so the throat is pointed the right place on the dish. A little up, down, right, left will kill signal. In and out like focusing a fixed focus camera.
Is it always 22.6 degrees, is that part of the math that makes these things work, or is the exact angle determined by the shape and size of the particular dish? None of my other more oval style dishes seem to be anywhere near that much of an angle.
Skew is not an option with this dish design, other than twisting the LNB. Elevation and azimuth is all it can handle. I suspect my issue has a lot to do with weight as primestar31 suggested and getting it mounted exactly right and tight enough to stay there. I'm also going to disassemble the thing and clean it, maybe some bugs have got in there and built a nest or something.
Satellite Meters
Primestar 84e LNB LO?
