You can't be grandfathered (It's not grandfather btw) for Distants as you refer to in the petition, because you are changing providers. When DISH stopped giving Distants any grandfathering went away.
Even if you have a waiver, you will need to get that again going through DISH as is clearly noted in the law. And good luck with that. Keep in mind if DISH has your locals even if you do not subscribe to them they can not give Distants unless you have a waiver which again, is not going to be easy for 99.9 percent of it's subscribers.
As for the very few areas that do not have all the locals it's entirely possible DISH will expand the use of a neighboring affiliate or a significantly viewed channel thereby providing networks to what few are in that category.
Also RV's and OTR truckers are easy to verify, home use is not.
If literally getting Distant networks from somewhere other than your own DMA at your home is what you are trying to do, find out if Direct TV takes applications for waivers and will honor them. (They are not obligated to) If they do, go with them and submit waivers and see what happens. I just don't envision DISH going back to them for home use.
If it is for RV use, you are not giving enough time for something to happen. You have three weeks to find out, and if no RV Distants and you must have them, go with Direct TV, those you can get.
