VIP722 signal down 20-30 points
mlcarson
18
I had Dish come out today to replace what I thought was simply an LNB problem. This was a dish 1000.2 and at least 2 of the 3 LNB's appeared to have broken seals and had water condensation in them. Rather than dealing with my dish, they were able to use another dish nearby but I still had the same signal strength. They tested the signal just before it went into the receiver and it was a good 20 points higher than what the receiver was showing. I ended up getting my 722 receiver replaced with a 722K and then the receiver signal strength seemed to match what the test device was showing.
Is there a difference in how the 722 and 722K measure signal strength or was this a real problem with the receiver? If it was really the receiver, any idea what might have caused a signal degradation with everything else working normally? I'm believing that it was the receiver because I had issues connecting to HD channels with the 722 on the new dish due to signal strength and the 722K worked fine connecting to the same cable.
no the 722 was likely failing - seen it many times the receiver shows a drop in signal pretty much what you saw vs the test meter behind the receiver. It is nothing to get concerned over but it happens - be sure its plugged into you're internet and run the diagnostics and send the data so the system can watch it from here on out. If the system see's this happening again be it from the receiver or the dish they will call you and send someone out at no cost to you.
Fox Sports Lands Golf's US Open
Moving
