A Few Questions, if I may:
1) Will the Hopper Transfer work with previously recorded material, or is it only possible with shows that will be recorded in the future (as demonstrated)?
Yes, you can prepare the content for the iPad when creating the timer or after its already recorded.
2) What does the Hopper w/Sling do with PTAT and Hopper Transfers? Are they capable of being transferred to an iOS device?
The PTAT event can be transferred but must be saved to the My Recordings folder first. Auto Hop does not work on these recordings on the IPad. Hopper Transfers is currently only supported on iPad.
3) Does the Hopper w/Sling make two copies of a program, one for playback in HD and the other for the iOS transfer?
It makes a copy once you select Prepare for Mobile during timer creation or after recorded, except when there are DRM restrictions. PPV, HBO, CINEMAX. When you attempt to prepare one of those events it will tell you that this transfer will remove the event from the Hopper.
4) Does the Hopper w/Sling and its Joeys still have access to a program that has been transferred to iOS? (related to #3 above)
If I transfer a movie I recorded on TBS, that event is still on the Hopper hard drive.
If I transfer Fast 5 recorded on HBO, it will warn me that Fast 5 will be removed from the Hopper and asks if I want to proceed.
5) Does the OTA module work with the Hopper Transfer function?
Yes
6) With which Wi-Fi standards does the Hopper w/Sling comply?
2.4 and 5 ghz (99 percent sure)
Thanks; I'll hang up and take my questions off the air...
