Uplink Activity for the week of April 24th 2006
Not exactly sure when this TP changed over, but TP 22 (12.530 GHz) on 129W is running 8PSK 5/6 FEC. There are just two test channels on it, but the total bandwidth provided by that TP is 50Mbit/s, about 7Mbit more than the 8PSK 2/3 FEC transponders.
Changing from 2/3 to 5/6 requires a higher signal to noise ratio, so I doubt we'd see it on live content anytime soon at 129. However the high powered spotbeams on E10 might be able to make this work.
Anyways, its a good sign they are testing it at least :)
Edit: Another interesting thing about that TP is that it appears they are testing a HD and a SD feed on the same TP.
Im sorry im probably a bit slow here, but what actually do all these moves mean.
Does it mean that they moved from 129 148 and 61.5 to 110 or 119 ? Does it mean they moved from 1 TP to another on the same bird or something else.
Im trying to understand the overall significance of all these moves.
TIA
BFG said:
Read the summary I made on post 15 and see if that helps
http://www.satelliteguys.us/showpost.php?p=548223&postcount=15
It does help in netting out this post, but i guess im trying to understand the bigger picture.
I did some more reading can i assume this is the 19-apr list of moves identifed in the xls here http://www.satelliteguys.us/showthread.php?t=62743 ?
i'm sort of unsure how excited i should be about this huge list of moves. As i said i am probably just being slow here.
Well the TP changes they did put E10 and E8 into their final configuration.
Dish still has some Second dish locals to move and superdish locals to move.
After that they will probably add HD locals to spot TPs that have room and have planned for.
Gosh Darn SBC internet has been down all morning but that hasnt stopped me from providing you your uplink reports.. IM now on "backup services" AKA Dialup LOL
Here you go :)
ECHOSTAR 110
9902 (TEST) Added To TP Frequency: 12.355 GHz TP 10
Echostar 148
470 (SPORT) Removed from TP Frequency: 12.428 GHz TP 15
No SD locals on 61.5
System Channel count reduced by 32
04-27-2006,03:13:04
148 ESPNU MOVED FROM Tp 19 ConUS beam on EchoStar 8 at 110w
TO Tp 3 ConUS beam on EchoStar 8 at 110w
157 IMF MOVED FROM Tp 19 ConUS beam on EchoStar 8 at 110w
187 HMC MOVED FROM Tp 3 ConUS beam on EchoStar 8 at 110w
TO Tp 19 ConUS beam on EchoStar 8 at 110w
194 DHOME MOVED FROM Tp 19 ConUS beam on EchoStar 8 at 110w
224 SAH MOVED FROM Tp 19 ConUS beam on EchoStar 8 at 110w
227 JTV MOVED FROM Tp 19 ConUS beam on EchoStar 8 at 110w
229 iSHOP MOVED FROM Tp 3 ConUS beam on EchoStar 8 at 110w
264 LIME MOVED FROM Tp 19 ConUS beam on EchoStar 8 at 110w
341 ENCRW MOVED FROM Tp 19 ConUS beam on EchoStar 8 at 110w
343 EACTN MOVED FROM Tp 3 ConUS beam on EchoStar 8 at 110w
488 TCLIP MOVED FROM Tp 19 ConUS beam on EchoStar 8 at 110w
493 ULTIM MOVED FROM Tp 3 ConUS beam on EchoStar 8 at 110w
494 TCLIP MOVED FROM Tp 19 ConUS beam on EchoStar 8 at 110w
843 HITN MOVED FROM Tp 19 ConUS beam on EchoStar 8 at 110w
855 FSESP MOVED FROM Tp 19 ConUS beam on EchoStar 8 at 110w
859 CNNES MOVED FROM Tp 19 ConUS beam on EchoStar 8 at 110w
870 HTV MOVED FROM Tp 19 ConUS beam on EchoStar 8 at 110w
883 LIME MOVED FROM Tp 19 ConUS beam on EchoStar 8 at 110w
6299 WGCB MOVED FROM Tp 3 Northeast beam on EchoStar 7 at 119w
TO Tp 18 Spotbeam 4 from Mount Jackson for EchoStar 10 at 110w
7380 WTNH MOVED FROM Tp 4 Spotbeam 4 from Mount Jackson for EchoStar 10 at 110w
TO Tp 20 Spotbeam 4 from Mount Jackson for EchoStar 10 at 110w
7381 WFSB MOVED FROM Tp 4 Spotbeam 4 from Mount Jackson for EchoStar 10 at 110w
7382 WVIT MOVED FROM Tp 4 Spotbeam 4 from Mount Jackson for EchoStar 10 at 110w
7383 WTIC MOVED FROM Tp 4 Spotbeam 4 from Mount Jackson for EchoStar 10 at 110w
7384 WTXX MOVED FROM Tp 1 Northeast beam on EchoStar 7 at 119w
TO Tp 3 Northeast beam on EchoStar 7 at 119w
7385 WCTX MOVED FROM Tp 1 Northeast beam on EchoStar 7 at 119w
7386 WEDH MOVED FROM Tp 1 Northeast beam on EchoStar 7 at 119w
7387 WUVN MOVED FROM Tp 1 Northeast beam on EchoStar 7 at 119w
7466 WTAJ MOVED FROM Tp 3 Northeast beam on EchoStar 7 at 119w
TO Tp 29 Spotbeam 9 from Mount Jackson for EchoStar 10 at 110w
7467 WJAC MOVED FROM Tp 3 Northeast beam on EchoStar 7 at 119w
7468 WWCP MOVED FROM Tp 3 Northeast beam on EchoStar 7 at 119w
7901 WTHI MOVED FROM Tp 24 ConUS beam on AMC 15 at 105w
TO Tp 7 Midwest beam on EchoStar 7 at 119w
7902 WTWO MOVED FROM Tp 24 ConUS beam on AMC 15 at 105w
7903 WFXW MOVED FROM Tp 24 ConUS beam on AMC 15 at 105w
TO Tp 5 Midwest beam on EchoStar 7 at 119w
7905 WUSI MOVED FROM Tp 24 ConUS beam on AMC 15 at 105w
7906 WVUT MOVED FROM Tp 24 ConUS beam on AMC 15 at 105w
8015 KBEH MOVED FROM Tp 21 ConUS beam on EchoStar 1 at 148w
TO Tp 3 South California beam on EchoStar 7 at 119w
8019 KHIZ MOVED FROM Tp 21 ConUS beam on EchoStar 1 at 148w
8021 KVMD MOVED FROM Tp 21 ConUS beam on EchoStar 1 at 148w
8077 WNVC MOVED FROM Tp 22 ConUS beam on EchoStar 3 at 61.5w
8080 WFDC MOVED FROM Tp 22 ConUS beam on EchoStar 3 at 61.5w
8081 WHUT MOVED FROM Tp 22 ConUS beam on EchoStar 3 at 61.5w
8082 WVPY MOVED FROM Tp 22 ConUS beam on EchoStar 3 at 61.5w
8084 WNVT MOVED FROM Tp 22 ConUS beam on EchoStar 3 at 61.5w
8085 WJAL MOVED FROM Tp 22 ConUS beam on EchoStar 3 at 61.5w
8106 WNET MOVED FROM Tp 3 Northeast beam on EchoStar 7 at 119w
TO Tp 1 Northeast beam on EchoStar 7 at 119w
8107 WLNY MOVED FROM Tp 13 ConUS beam on Rainbow 1 at 61.5w
8108 WXTV MOVED FROM Tp 3 Northeast beam on EchoStar 7 at 119w
8109 WNJU MOVED FROM Tp 13 ConUS beam on Rainbow 1 at 61.5w
8110 WFTY MOVED FROM Tp 13 ConUS beam on Rainbow 1 at 61.5w
8112 WLIW MOVED FROM Tp 20 ConUS beam on EchoStar 3 at 61.5w
8113 WNJB MOVED FROM Tp 20 ConUS beam on EchoStar 3 at 61.5w
8114 WNYE MOVED FROM Tp 20 ConUS beam on EchoStar 3 at 61.5w
8115 WMBC MOVED FROM Tp 20 ConUS beam on EchoStar 3 at 61.5w
8116 WRNN MOVED FROM Tp 20 ConUS beam on EchoStar 3 at 61.5w
8166 WGTW MOVED FROM Tp 20 ConUS beam on EchoStar 3 at 61.5w
8182 WYFF MOVED FROM Tp 7 Carolinas beam on EchoStar 7 at 119w
TO Tp 5 Carolinas beam on EchoStar 7 at 119w
8183 WHNS MOVED FROM Tp 7 Carolinas beam on EchoStar 7 at 119w
8184 WBSC MOVED FROM Tp 7 Carolinas beam on EchoStar 7 at 119w
8185 WASV MOVED FROM Tp 7 Carolinas beam on EchoStar 7 at 119w
8186 WNTV MOVED FROM Tp 20 ConUS beam on EchoStar 3 at 61.5w
8186 WNTV, WNTV REMOVED FROM Tp 21 ConUS beam on EchoStar 5 at 129w
8190 WUNC MOVED FROM Tp 7 Carolinas beam on EchoStar 7 at 119w
8192 WGGS MOVED FROM Tp 20 ConUS beam on EchoStar 3 at 61.5w
8192 WGGS, WGGS REMOVED FROM Tp 21 ConUS beam on EchoStar 5 at 129w
8228 KDTV MOVED FROM Tp 7 North California beam on EchoStar 7 at 119w
TO Tp 31 Spotbeam 43 from Spokane for EchoStar 10 at 110w
8229 KSTS MOVED FROM Tp 27 ConUS beam on EchoStar 1 at 148w
8229 KSTS, KSTS REMOVED FROM Tp 20 ConUS beam on EchoStar 5 at 129w
8230 KFSF MOVED FROM Tp 7 North California beam on EchoStar 7 at 119w
8231 KTNC MOVED FROM Tp 27 ConUS beam on EchoStar 1 at 148w
8231 KTNC, KTNC REMOVED FROM Tp 21 ConUS beam on EchoStar 5 at 129w
8232 KMTP MOVED FROM Tp 27 ConUS beam on EchoStar 1 at 148w
8232 KMTP, KMTP REMOVED FROM Tp 21 ConUS beam on EchoStar 5 at 129w
8233 KRCB MOVED FROM Tp 27 ConUS beam on EchoStar 1 at 148w
8233 KRCB, KRCB REMOVED FROM Tp 21 ConUS beam on EchoStar 5 at 129w
8234 KTEH MOVED FROM Tp 27 ConUS beam on EchoStar 1 at 148w
8234 KTEH, KTEH REMOVED FROM Tp 21 ConUS beam on EchoStar 5 at 129w
8235 KCSM MOVED FROM Tp 27 ConUS beam on EchoStar 1 at 148w
8235 KCSM, KCSM REMOVED FROM Tp 20 ConUS beam on EchoStar 5 at 129w
8236 KTLN MOVED FROM Tp 27 ConUS beam on EchoStar 1 at 148w
8236 KTLN, KTLN REMOVED FROM Tp 20 ConUS beam on EchoStar 5 at 129w
8237 KTSF MOVED FROM Tp 27 ConUS beam on EchoStar 1 at 148w
8237 KTSF, KTSF REMOVED FROM Tp 20 ConUS beam on EchoStar 5 at 129w
8239 KFTY MOVED FROM Tp 27 ConUS beam on EchoStar 1 at 148w
8239 KFTY, KFTY REMOVED FROM Tp 20 ConUS beam on EchoStar 5 at 129w
8240 KRON MOVED FROM Tp 7 North California beam on EchoStar 7 at 119w
8300 WSB MOVED FROM Tp 3 ConUS beam on EchoStar 8 at 110w
8301 WGCL MOVED FROM Tp 3 ConUS beam on EchoStar 8 at 110w
8302 WXIA MOVED FROM Tp 3 ConUS beam on EchoStar 8 at 110w
8303 WAGA MOVED FROM Tp 3 ConUS beam on EchoStar 8 at 110w
8490 WLS MOVED FROM Tp 3 ConUS beam on EchoStar 8 at 110w
8491 WBBM MOVED FROM Tp 3 ConUS beam on EchoStar 8 at 110w
8492 WMAQ MOVED FROM Tp 3 ConUS beam on EchoStar 8 at 110w
8493 WFLD MOVED FROM Tp 3 ConUS beam on EchoStar 8 at 110w
8494 WGN9 MOVED FROM Tp 7 Midwest beam on EchoStar 7 at 119w
TO Tp 31 Spotbeam 19 from Monee for EchoStar 10 at 110w
8495 WPWR MOVED FROM Tp 7 Midwest beam on EchoStar 7 at 119w
8496 WTTW MOVED FROM Tp 7 Midwest beam on EchoStar 7 at 119w
8497 WCIU MOVED FROM Tp 5 Midwest beam on EchoStar 7 at 119w
8498 WGBO MOVED FROM Tp 27 ConUS beam on EchoStar 3 at 61.5w
8498 WGBO, WGBO REMOVED FROM Tp 15 ConUS beam on EchoStar 5 at 129w
8499 WSNS MOVED FROM Tp 27 ConUS beam on EchoStar 3 at 61.5w
8499 WSNS, WSNS REMOVED FROM Tp 15 ConUS beam on EchoStar 5 at 129w
8500 WXFT MOVED FROM Tp 27 ConUS beam on EchoStar 3 at 61.5w
8500 WXFT, WXFT REMOVED FROM Tp 15 ConUS beam on EchoStar 5 at 129w
8501 WYCC MOVED FROM Tp 27 ConUS beam on EchoStar 3 at 61.5w
8501 WYCC, WYCC REMOVED FROM Tp 15 ConUS beam on EchoStar 5 at 129w
8502 WYIN MOVED FROM Tp 27 ConUS beam on EchoStar 3 at 61.5w
8502 WYIN, WYIN REMOVED FROM Tp 15 ConUS beam on EchoStar 5 at 129w
8503 WJYS MOVED FROM Tp 27 ConUS beam on EchoStar 3 at 61.5w
8503 WJYS, WJYS REMOVED FROM Tp 15 ConUS beam on EchoStar 5 at 129w
8504 WOCK MOVED FROM Tp 5 Midwest beam on EchoStar 7 at 119w
8590 KDNL MOVED FROM Tp 5 Midwest beam on EchoStar 7 at 119w
TO Tp 29 Spotbeam 19 from Monee for EchoStar 10 at 110w
8591 KMOV MOVED FROM Tp 5 Midwest beam on EchoStar 7 at 119w
8592 KSDK MOVED FROM Tp 5 Midwest beam on EchoStar 7 at 119w
8593 KTVI MOVED FROM Tp 5 Midwest beam on EchoStar 7 at 119w
8594 KPLR MOVED FROM Tp 5 Midwest beam on EchoStar 7 at 119w
8596 KETC MOVED FROM Tp 5 Midwest beam on EchoStar 7 at 119w
8597 KNLC MOVED FROM Tp 27 ConUS beam on EchoStar 3 at 61.5w
8600 WPXS MOVED FROM Tp 27 ConUS beam on EchoStar 3 at 61.5w
8601 WRBU MOVED FROM Tp 27 ConUS beam on EchoStar 3 at 61.5w
8621 KBCB MOVED FROM Tp 2 ConUS beam on EchoStar 2 at 148w
TO Tp 3 Northwest beam on EchoStar 7 at 119w
8622 KWDK MOVED FROM Tp 2 ConUS beam on EchoStar 2 at 148w
8623 KHCV MOVED FROM Tp 2 ConUS beam on EchoStar 2 at 148w
8624 KWOG MOVED FROM Tp 2 ConUS beam on EchoStar 2 at 148w
8641 KTNC MOVED FROM Tp 27 ConUS beam on EchoStar 1 at 148w
8641 KTNC, KTNC REMOVED FROM Tp 21 ConUS beam on EchoStar 5 at 129w
8662 WUNC MOVED FROM Tp 7 Carolinas beam on EchoStar 7 at 119w
8750 WTVD MOVED FROM Tp 7 Carolinas beam on EchoStar 7 at 119w
TO Tp 29 Spotbeam 2 from Mount Jackson for EchoStar 10 at 110w
8751 WRAL MOVED FROM Tp 7 Carolinas beam on EchoStar 7 at 119w
8752 WNCN MOVED FROM Tp 7 Carolinas beam on EchoStar 7 at 119w
8753 WRAZ MOVED FROM Tp 7 Carolinas beam on EchoStar 7 at 119w
8754 WLFL MOVED FROM Tp 7 Carolinas beam on EchoStar 7 at 119w
8755 WRDC MOVED FROM Tp 7 Carolinas beam on EchoStar 7 at 119w
8756 WUNC MOVED FROM Tp 7 Carolinas beam on EchoStar 7 at 119w
8757 WUVC MOVED FROM Tp 7 Carolinas beam on EchoStar 7 at 119w
8770 WCVB MOVED FROM Tp 1 Northeast beam on EchoStar 7 at 119w
TO Tp 26 Spotbeam 4 from Mount Jackson for EchoStar 10 at 110w
8771 WBZ MOVED FROM Tp 1 Northeast beam on EchoStar 7 at 119w
8772 WHDH MOVED FROM Tp 1 Northeast beam on EchoStar 7 at 119w
8773 WFXT MOVED FROM Tp 1 Northeast beam on EchoStar 7 at 119w
8774 WLVI MOVED FROM Tp 1 Northeast beam on EchoStar 7 at 119w
8776 WGBH MOVED FROM Tp 1 Northeast beam on EchoStar 7 at 119w
8777 WZMY MOVED FROM Tp 22 ConUS beam on EchoStar 3 at 61.5w
8778 WUNI MOVED FROM Tp 22 ConUS beam on EchoStar 3 at 61.5w
8779 WNEU MOVED FROM Tp 20 ConUS beam on EchoStar 7 at 119w
8780 WUTF MOVED FROM Tp 22 ConUS beam on EchoStar 3 at 61.5w
8781 WENH MOVED FROM Tp 22 ConUS beam on EchoStar 3 at 61.5w
8782 WGBX MOVED FROM Tp 22 ConUS beam on EchoStar 3 at 61.5w
8783 WYDN MOVED FROM Tp 22 ConUS beam on EchoStar 3 at 61.5w
8784 WMUR MOVED FROM Tp 22 ConUS beam on EchoStar 3 at 61.5w
8785 WWDP MOVED FROM Tp 13 ConUS beam on Rainbow 1 at 61.5w
8790 KGTV MOVED FROM Tp 3 South California beam on EchoStar 7 at 119w
TO Tp 27 Spotbeam 39 from Spokane for EchoStar 10 at 110w
8791 KFMB MOVED FROM Tp 3 South California beam on EchoStar 7 at 119w
8792 KNSD MOVED FROM Tp 3 South California beam on EchoStar 7 at 119w
8793 XETV MOVED FROM Tp 3 South California beam on EchoStar 7 at 119w
8796 KPBS MOVED FROM Tp 3 South California beam on EchoStar 7 at 119w
8797 KUSI MOVED FROM Tp 3 South California beam on EchoStar 7 at 119w
8798 KZSD MOVED FROM Tp 3 South California beam on EchoStar 7 at 119w
9015 WHTM MOVED FROM Tp 3 Northeast beam on EchoStar 7 at 119w
TO Tp 4 Spotbeam 4 from Mount Jackson for EchoStar 10 at 110w
9016 WHP MOVED FROM Tp 3 Northeast beam on EchoStar 7 at 119w
9017 WGAL MOVED FROM Tp 3 Northeast beam on EchoStar 7 at 119w
9018 WPMT MOVED FROM Tp 3 Northeast beam on EchoStar 7 at 119w
9020 WLYH MOVED FROM Tp 3 Northeast beam on EchoStar 7 at 119w
9021 WITF MOVED FROM Tp 3 Northeast beam on EchoStar 7 at 119w
9022 WGCB MOVED FROM Tp 3 Northeast beam on EchoStar 7 at 119w
9401 HITN MOVED FROM Tp 19 ConUS beam on EchoStar 8 at 110w
9812 XKGTV, REMOVED FROM Tp 3s5 on EchoStar 7 at 119w
9813 XKFMB, REMOVED FROM Tp 3s5 on EchoStar 7 at 119w
9814 XKNSD, REMOVED FROM Tp 3s5 on EchoStar 7 at 119w
9815 XXETV, REMOVED FROM Tp 3s5 on EchoStar 7 at 119w
9816 XWCVB, REMOVED FROM Tp 1s13 on EchoStar 7 at 119w
9817 XWBZ, REMOVED FROM Tp 1s13 on EchoStar 7 at 119w
9818 XWHDH, REMOVED FROM Tp 1s13 on EchoStar 7 at 119w
9819 XWFXT, REMOVED FROM Tp 1s13 on EchoStar 7 at 119w
9832 XKDNL, REMOVED FROM Tp 5s11 on EchoStar 7 at 119w
9833 XKMOV, REMOVED FROM Tp 5s11 on EchoStar 7 at 119w
9834 XKSDK, REMOVED FROM Tp 5s11 on EchoStar 7 at 119w
9835 XKTVI, REMOVED FROM Tp 5s11 on EchoStar 7 at 119w
9840 XWTVD, REMOVED FROM Tp 7s14 on EchoStar 7 at 119w
9843 XWRAZ, REMOVED FROM Tp 7s14 on EchoStar 7 at 119w
CHANGE COUNT 178
These are HARTFORD / New Haven Locals NOT Mount Jackson
WOW I thought May 5th would be the switch time for my Terre Haute Locals Woke up and they were on 119!!!!! They going to stay there from now on i take it or switch to 110. Also the transponder my 2 distant from indy are running on 110 tp 1 and signal sucks like 65 but other tp's are 100's!
Mike
Mike
WTHR and WRTV are on Tp 18 Spotbeam 13 at 110.
Dish 500 local no 2nd dish required
Keep an eye on your Dish bill.
