Hi guys, first time poster.
I've been running a 311 receiver for the past year year with no issues. I recently purchased a 512 dvr receiver and am having issues getting a signal to both inputs.
The dish hasnt moved or been damaged in any way so I have no idea why I'm not getting a signal. I'm running dual LNB's, into a sw44 switch, into a dp plus separator, then finally into sat 1 and sat 2 inputs. When I run a check with both inputs connected I get signal through to sat input 1 (110 + 119) but nothing to sat input 2 (says not verified), and thus cannot proceed.
When I disconnect sat input 2, and re run a check, I get an ok signal (110 + 119) and am able to watch TV but cannot record and watch at the same time or use PIP since input 2 is disconnected.
It appears that signal to 119 is weak, could the this be why once the signal is split I dont get anything? Maybe readjust the dish?
any help would be much appreciated! thanks!
