Why wouldn't they see each others recordings?they better update the H1 otherwise there will be some unhappy customers that have both a H1 & H2 that won't see each others recordings
Sent from my SAMSUNG-SM-G900A using Tapatalk
The new UI doesn't seem to talk to the old UI.Why wouldn't they see each others recordings?
Well now not sure how that would work out for them.The new UI doesn't seem to talk to the old UI.
From what has been said around here the New UI is coming for the Hopper 1. It's just behind because they are putting all the effort into the UI for the H2 and H3 as you have to have these to use the 4K Joey. Once they get the UI for the H2 done I'm sure they will get going on it for the H1 again.Well now not sure how that would work out for them.
Guess they will be giving me a free upgrade.
I can tell you right now that is unacceptable otherwise.
Ok even after the nightly reboot the Super Joey is doing the same thing. Just now I reset the Hopper and then the Super Joey and it is still doing the same behavior. What should I do?Turn it off for 10 minutes and try again. If that doesn't work leave it off over night and check again in the morning. My SJ is working perfectly
I just checked it and it says that the Super Joey is linked and the quality is strong.In the mean time try and go in to settings and make sure the SJ is linked to the hopper. You may need to re-link it.
Thank you Patrick for letting me know. I noticed that when paging through the guide it now seems slower with the Carbon update. Have you noticed this and has the U203 update made a difference as far as you can tell?Other than that I'm not sure what else to try. It seems to be working for everyone else. Maybe just a bug in the software and maybe U203 will fix it.
Well I chickened out on the download. After thinking that I screwed up my 2 joeys the last time l can't muster the courage to do it. I'll wait for the H3.Thanks!!
