That would be just like me asking for YouTube (even non-4K) on the Hopper Duo: It ain't happening.Still no 4K YouTube.
One H3 with Dish-supplied dual tuner dongle, 3 wired (coax) Joey 3.0s all MoCA (linked, strong) and net connection is relayed. Problem started with our OTA antenna install and removing the dongle immediately stops the issue (mentioned by others elsewhere in this forum) but then the Hopper wants to reboot anyway.Can you summarize your setup for those of us who haven't seen and/or don't remember what it is? Your pixelating Joey is on only MoCA, or only Ethernet, or both? Is the Hopper set to relay Internet connections? My tech set up my Joey's on both, and turned off the H3 forwarding feature.
Okay, I'll go ahead and do that. Which chip do you recommend? (Sorry, you kind of made it sound like that was a change we could do ourselves.) If Dish actually did that, they would still have to change the model number for the new Hopper 3's, to distinguish them from the old Hopper 3's with the old chip set. It probably wouldn't be enough of a change to warrant calling it a Hopper 4. Maybe Hopper 3-2?Unless you change the chip set in the Hopper3 you will not get 4K YouTube on the Hopper3. ...
Alternatively, maybe they could come up with some accessory for this purpose, similar to a Hopper Snap. It would add whatever new chips and additional memory that may be necessary in order for the older Hoppers to support the new apps.... It is a hardware restriction.
Thanks, I did not know that. I thought the Hopper was already set up to handle 4K, even in the apps.Unless you change the chip set in the Hopper3 you will not get 4K YouTube on the Hopper3. It is a hardware restriction.
The reboot is necessary to remove the OTA channels from the guide, since the dongle is no longer connected. This prevents any attempt to tune to those channels when the tuner is no longer there. In other words, the software was not set up to accommodate a temporary removal of the dongle in order to fix another issue. It assumes that you are removing the OTA tuners "permanently."One H3 with Dish-supplied dual tuner dongle, 3 wired (coax) Joey 3.0s all MoCA (linked, strong) and net connection is relayed. Problem started with our OTA antenna install and removing the dongle immediately stops the issue (mentioned by others elsewhere in this forum) but then the Hopper wants to reboot anyway.
One H3 with Dish-supplied dual tuner dongle, 3 wired (coax) Joey 3.0s all MoCA (linked, strong) and net connection is relayed. Problem started with our OTA antenna install and removing the dongle immediately stops the issue...
Oh this I know...guess it was a poorly veiled attempt at sarcasm since rebooting the Hopper is the only way to fix this issue right now and either way the Hopper needs to be rebootedThe reboot is necessary to remove the OTA channels from the guide, since the dongle is no longer connected. This prevents any attempt to tune to those channels when the tuner is no longer there. In other words, the software was not set up to accommodate a temporary removal of the dongle in order to fix another issue. It assumes that you are removing the OTA tuners "permanently."
Yep... I've been having the same Joey pixelating issue for a few months. I didn't know it was related to the OTA dongle until reading DJ's post.
Are you both using the same model of dual-tuner OTA dongle? (The black Lark adapter supplied by Dish, with the attached USB cable.) I am wondering if this issue is specific to that model, or if the older Hauppauge dual-tuner adapter (the one with the detachable USB cable) has the same issue.I'm another one with the same issue... pixellation on the Joey. I have a Hopper 3 and one Joey. And a dual OTA tuner on the Hopper. Only fix is to reboot the Hopper... rebooting the Joey does nothing. I do believe it is the OTA dongle getting too warm. I turned it on its side over the weekend (had to unplug it and reboot as described above) in the hopes that it will allow more cooling. So far so good, but its only Monday.
Since this update I got on the 7th, we have ota recordings now with sound fluctuations like they are under water talking.
I'll check this on mine tonight as I have not noticed any problems with this new update.Since this update I got on the 7th, we have ota recordings now with sound fluctuations like they are under water talking. Thank goodness I back up all my recordings on my Tablo. It has performed flawlessly for me the last 2 years I've had it. Can't say the same about my DISH dvrs.
Long history of dvr problems and bugs going back to 99 and my first dishplayer/webtv receiver. My wife asked me why DISH doesn't test their software out before they release it and I told her they do . They test it on their customers and then based on our complaints they make more changes and tweaks to fix something they broke in the software download.
Thanks for trying.
It will prove that you have a magic hub. What happens when you power your magic hub? Does the 6TB disk disappear?
I did it last night, I plugged in the power adapter and restarted the Hopper. The 2TB drive did not come online.
So unplug those power adapters to your hubs!
Well, that's interesting. When I plug my earlier 1.5TB disk in, and then reboot the Hopper, that's the only disk that shows up. In other words, the 6TB disk becomes invisible. I always suspected you had a magic hub!
I cannot unplug my hub because it's embedded in the 6TB enclosure. I may have an unpowered hub lying around. Do you think that would work? I guess I could buy the exact model of your powered hub and see what happens...
