viewsat receiver, 90cm. dish, universal lnb...But dont get good signal, or channels... anyone know the settings,? do I need another lnb, or dish, receiver?? my location is chicago, usa
Does the viewsat have a quality indicator, usually receivers have a signal strength and a quality level, the signal level does not matter, even if you connect the receiver to the lnb it will show a signal, quality level is what is important and only shows if you are locked on a transponder.
Until you can get the Quality off of 0 you are not on a satellite with that transponder active, you need to try a different transponder, or you need to adjust your dish.
you need to manually put a strong transponder for me it was 11884 V 27500 in order to see any quality signal, and then from there gotta start looking, the dish is going to look like is facing the ground, so have patience.
