Trying to get my motor/dish set up. One thing I don't understand is why the elevation set at true south is so different from the actual true south sattelite elevation.
My true south sat is Nimiq 4 since it is located at 82W and my long is 81.1W. The dish elevation is to be set at 56.7 degrees per the sat finder instructions. My lat is 28.55 and I have that set as my motor elevation. According to the motor instructions, the true south position should be set for the dish at (30 degrees minus declination angle). My declination angle at this position is 4.8 so I set the dish to 25.2 degrees elevation. This doesn't make sense to me though because if true south is supposed to be at the top of the arc, then how is it that if it just moves over 1 degree from true south to the west (to locate nimiq 4), the elevation is set at 56.7 degrees which is much higher elevation. I was thinking it had to do with the skew making the dish come down a little, but it's only 1.8 degree skew since nimiq 4 is so close to true south position. This has really been bugging me. Thanks in advance.
