Trouble Shooting Question
Sparty10
72
My Directv Receiver is only showing shows in 480p when my TV is capable of 1080i. When i hit the format button my only choices are 480pstretch, crop, and pillar box.
Not sure which receiver you have but its problably something like this.
Menu - Help & Settings - Setup - HDTV - TV Resolutions
You can select which ones to use. You can also define if your screen is wide or standard using TV Ratio.
Yes, and Resolutions is on a tab at the top of the screen (kinda easy to miss.)
Thanks guys, the problem was on theactul receiver i had the resolution buton set on 480
one touch to guide on R15-100
Multiswitch Question
