I'm a bit confused by transponders vs spotbeams, particularly as they relate to what is listed on the Echostar Knowledge Base hosted by DBSTalk.com.
For example, at http://www.ekb.dbstalk.com/110list.htm for Dallas SD Locals, I see the 'TP' is listed as '20s21', or '29s21' (depending on the channel). Then on the maps of TPs listed at http://www.ekb.dbstalk.com/satmaps.htm, I clicked on the 20 and 29 maps within the "Larger and more detailed maps of E*10 spot beams provided by James Long at DBSTalk.Com" section and see coverage area 'ovals' in Texas for both TP 20 and TP 29 for my area of Texas. The map for TP 29 lists the oval as T21. Wondering what T21 means? The map for TP20 doesnt label any of the ovals.
Real reason I'm asking, besides just wanting to understand what #s# means, is because I 'moved' to Dallas from Austin and get a 105 signal for 20s21 channels, but no signal for 29s21 channels. The 'ovals' coverage area for both the 20TP and 29TP on the maps from E* Knowledge Base seem identical, so just thought it weird that I get such a strong signal for the SD locals on the 20 TP, and no signal for the SD locals on the 29 TP.
Any input would be appreciated.
