can you hook up a tivo to a vip 622 and have 4 tuners.or do one dvr lock out the other.thanks for any info.
A TiVo cannot tune satellite programming so it ends up being a single program recording device when connected to a satellite receiver. TiVos are relatively limited for satellite use.can you hook up a tivo to a vip 622 and have 4 tuners.or do one dvr lock out the other.
Not in the way that the original question was posed. You can record a single program in SD resolution from the TV1 output and you would need to relinquish control of TV1 for the duration of the recording.but will it work?
Nor will it subtract any either! The OP phrased that question oddly, and it's hard to tell what he or she wants to do. But the 622 has 2 satellite tuners and 1 OTA ATSC tuner, and that's independent of any external boxes. So all those tuners can be used to DVR programs. Add a Tivo and you've got whatever tuners the Tivo has. (I don't know which model you have, but I would guess it has another OTA tuner, either an ATSC or NTSC tuner, or both.) If the Tivo has an ATSC tuner, then it can record OTA broadcasts independently of the 622. If it has an NTSC tuner, you could play back either a recorded program or a live program from the 622 and record it (again?) onto the Tivo. It all depends on what you want to do.The TiVo won't magically add tuners to the ViP622.
I disagree. While the TiVo is recording, TV1 is entirely unavailable for other uses.Nor will it subtract any either!
While what "TV" is recording? Now you're being as cryptic as the OP!I disagree. While the TV is recording, TV1 is entirely unavailable for other uses.
Fixed that late-night boo-boo.While what "TV" is recording? Now you're being as cryptic as the OP!
The assumption I made was that the OP wanted to be able to record four (or five!) different programs at once using the automatic TiVo functions and that's not possible. Without the special TV2 IR adapter the TiVo can automatically control only TV1.But if the TV1 or 2 output were being used to play back a previous recording, then TV1 or 2 or the OTA input tuners on the 622 are not precluded from recording something else, such as 2 sat programs and 1 OTA program. Operation in this fashion is non-blocking.
