Titanium Satellite is providing this information for educational purposes only. We do not recommend any user to open or modify the ASC1. Dangerous voltages that may injure or kill are present inside the ASC1 case. Only qualified and trained electronics technicians should open and service electronic equipment. Titanium Satellite will not be responsible for any damages, injury or death that might be the result of opening or modifying this device. Remember to always disconnect the power source and follow proper safety and discharge procedures when servicing electronics.
Current ASC1 owners may keep the first generation unit for their own personal use. The first gen ASC1 may be gifted to another party, but only with a disclaimer that the gifted ASC1 is without support or warranty. I only ask that these original ASC1 units not be sold, bartered or traded.
Please note that Titanium Satellite support for these original ASC1 units will end upon receipt of the replacement ASC1. Titanium Satellite will not provide parts, warranty, replacements or repairs for the original ASC1 units. The original ASC1 units are easy to identify as they do not have a serial number affixed. All warrantied ASC1 units have been issued a serial number that is recorded in our system, labeled on the bottom of the case and another on the outside of the giftbox. The Titanium Satellite ASC1 warranty, parts, replacements and repairs are only available for serialized units provided with an original proof of purchase.
This hardware modification is provided for upgrading first generation Titanium Satellite ASC1 controllers. This hardware modification will provide 22KHz/DiSEqC commands to be passed-through the ASC1 from a connected STB to upstream switches and provide increased compatibility with DiSEqC 1.2 commands. First generation ASC1 controllers are not covered by warranty and will not be provided with replacement parts or support. Surface mount components are easily damaged by improper handling, incorrect tools and overheating.
A metric hex head tool type M3 will be used to remove the 4 screws on the faceplate and 4 screws in the base. The faceplate is removed and the cables disconnected to gain access to removing the main PCB. Once all cables are unplugged from the PCB, remove the 4 Phillips head screws securing the PCB to the plate. After modifications are completed, reverse these steps to reassemble.
Have Fun!!!
Have Fun!!!
