Well, it's been going for a bit of time i think. I have had problems before and it corrected itself or a power cycle fixed it.. I didn't know what exactly was wrong, well, after swapping cables and and taking my signal tester outside, i now know 100% that LNBF port 1 is no longer allowing signal. I tested by using a patch cable to the signal tester directly to the LNBF. Cable screwed into LNB 2, works, cable screwed into LNB1 doesn't work, and i even tested a second cable with the same result.
Luckily i have a spare C2PLL that is still unopened from the box that was planned for another dish.
Hey, Titanium, how long are your warranties for these things? I think its about 1-2 years old. If I'm out of luck, i guess ill have to buy another one so i can replace the one i unboxed...
I wonder what happened? Can i open this thing up and see if something got corroded? The device looks in outstanding condition except for a little bit of rust where the screw clamps down on the LNBF to hold it in place.
