Time to upgrade? cable question (and maybe more)
Could you please elaborate on the details of the cabling (and this "node" you refer to), so I better understand?
Right now, we have HDMI (I believe) running from the actual sat dish (on the roof) to a plastic junction box on the exterior of our house. (Is this plastic jucntion box the "node" you're referring to? If not, what is the node?) Then there are 3 coax cables going out from the plastic junction box to....
  • one coax goes from the junction box to the 722 in the living room (there's a HD TV#1 connected directly to the 722 via HDMI)
  • one coax goes from the junction box to TV#2 in the upstairs bedroom (this has only been receiving an SD signal but we want HD up there now)
  • one coax goes from the junction box to the 211k connected to TV#3 in an upstairs office (this is an older, small TV and currently doesn't need HD)
You could get HD to TV 2 location by moving your 211K to TV 2 then going to the junction box and switching the wires going to TV 2 and TV 3. TV 3 would then connect the same as TV 2 used to and TV 2 would have its own box. The only drawback is it would not share recordings with TV 1. If you want to share HD recordings with TV 1 you must go with a Hopper system.
