I recently experienced an indirect lightning strike and lost everything that was connected to the LAN in the family room. When the strike hit, it threw 3 breakers, and 1 GFI in the kitchen. Once I reset everything, I was at first puzzled as to why I lost the equipment that I did since everything was on surge protectors. Then I realized that two items in the room survived. The stereo and the Nintendo Wii. That's when it occurred to me what probably happened. I use Powerline Adapters to extend my network between the home and my office, which is a separate structure. You can't plug the powerline adapters into a surge supressor, because it will filter out the higher frequencies that it uses to communicate. That one powerline adapter was one of the items that died from the strike, and it was connected to a network switch. Everything connected to the switch took a hit as well, including the vip722k. The stereo and Wii were not connected to the switch. So I figured I had a good idea on where that transient voltage traveled from.
So I installed a whole house surge protector, as well as threw a network cable surge protector on the line coming form the powerline adapter as my first steps. I also insured proper grounding both inside and out of the Sat. system.
On the Sat. side of things, not only did I lose the 722, but one biplexer, and the TRIA <--? on the dish itself. So now I'm wondering if the excessive voltage didn't come in through the coax, through the receiver, out the ethernet port, through my switch, to the other A/V equipment.
Figuring I would never really know, I started looking for surge protection for the lines coming into the house. Did my research here, but am still a little confused. I see that it would probably degrade the picture and/or cause other issues.
Am I worrying too much about this? I would just really hate to have something travel down the coax and bypass everything I put in place for protection. I know nothing will save me from a direct strike, but I'm just trying to button things down as much as possible.
Thanks,
Rich
Thanks,
Rich
