Saw this video and immediately thought it would be perfect for my Dish to prevent the occasional snow caused signal loss...
This sounds good, but where can it be purchased?
Dan
This will do nothing for the Signal Loss issue.
Signal loss is due to the storm clouds blocking the signal between your dish and the Sat.
Nothing you can do about that.
Rain fade is NOT the only cause of signal loss. A misaligned or physically blocked (including snow or frost coverage) dish will report the same error.This will do nothing for the Signal Loss issue.
Regrettably, Florida often has its own manner of signal issues (rain fade). Arizona would probably be a better choice for avoiding signal issues.The best solution to snow on your dish is move to Florida.
A friend of mine with DirecTV uses cooking spray to get the snow to slide off his dish. I surprisingly had no signal loss at all last winter when I first got Dish, considering how heavy the snow is around here in the wintertime.
Lake effect snow tends to be dry and that doesn't stick to the dish. It's the heavy wet snow that causes problems. I'm in the Lake Ontario snow squall area, east of Rochester.
