Off-center picture issue...
Don't have the 942, but I may have an inkling of what may be your problem. It might be your TV's DVI/HDMI setup, not the 942. My bedroom Samsung 26" HD set has DVI, and when we had Voom installed
, I took advantage of that input. Well, I immediately noticed the same left shift of the picture when looking at the tuner through the DVI. I pondered, then I went into the TVs set-up for the DVI input on a lark, and saw that there are two DVI standards, SMPTE and something else (sorry, name escapes me. anyone? it was alpha-numeric jibberish--ER1183-H441 or something). It was set to SMPTE by default, and when I switched it to the other DVI standard, voila, the picture centered out perfectly.
Hope this helps.
csschrot said:Scott, We have a 942 set up in the show room and was wondering if you are seeing the samething we are. To be honest I haven't had the time to go through the manual or check out the web. Here is the issues we are having. First we notice the picture is shifted to the left on the screen. (We are using the 34" DISH monitor.) I can't find anything in either menu to center the picture. Also the format is not working.
Are you seeing the same problems?
Shawn
Hope this helps.
