I have a ViP211 (and 3 other receivers). This morning, my ViP211 will only pick up 1 of 3 satellites (I get 119, 129, and 110 on all others). I ran a check switch test and it changed from "Switch - DPP44 w/ separator" to "Switch - DP Feed". It appears that it isn't seeing the DPP44 switch anymore. I can reboot the receiver and it will pick up a different satellite almost every time (but not all three). The other receivers work fine. My question is: Does each receiver auto-detect the switch type or can you set it manually (if so, where)? Any other ideas? I called tech support, they had no insight (except telling me that it will be $30 to send a tech out next week ). I am troubleshooting myself in the meantime. I am going to switch out the feeds from the switch to see if it is a bad port or if I have a problem with my ViP211.
Side note: I have had tons of problems with my DPP44 switch over the last two years. I have had two go out and had to be replaced. Checked the power there and it appears nice and stable. Anyone else had trouble with this switch?
Thanks!
Thanks!
