Tables Added
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,611
29,122
Newington, CT
Ok I think I figured out what P Smith was looking for...
Code:
[table="head"]head col1|head col2|head col3
row1 col1|row1 col2|row1 col3
row2 col1|row2 col2|row2 col3[/table ]
row2 col1|row2 col2|row2 col3[/table]
[table="head"]head firstcol|head secondcol2|head thirdcol3
first entry|second entry|third entry
Just testing -- and it works. The row2 col1 is just text. You can replace it with whatever text you want, as I did in the example above.
Code:
row2 col1|row2 col2|row2 col3[/ table]
Testing:
[table=head]Column A|Column B|Column C|Column D4
A1|B1|C1|D1
A2|B2|C2|D2
[/table]
Interesting.... how does it know when to create a new row ? Is it simply by creating a new line ?
I tried things like "row1 col1 value" or "row1 value" and so on. Quite a few variations like I said above with no luck.
[table="head"]first column|second column | third column | fourth column
first entry|second entry|third entry|fourth entry
second entry|row2 col2|row2 col3| row2 col4 [/table]
another test
Code:
second entry|row2 col2|row2 col3| row2 col4   [/ table]
You can call the table anyname. The first line is the column headers; then each line below it represents the row data. Kind of easy!
Hall: Just add a row. Its a literal table.
third row 1|another one|and another| and a fourth
fourth row 1|another one|and another| and a fourth [/table]
Code:
fourth row 1|another one|and another| and a fourth  [/ table]
[table=head] Station Name | Channel # | Dish Channel #
WHIO | 7 | 7007
WDTN | 2 | 7002
WKEF | 22 | 7022
WRGT | 45 | 7045 [/table] Figured it out.... Newline or carriage returns automatically create a new row. Also, the "|" ends any formatting. For my header row, in order to bold each item, you have to put the vB bold code, text, end-bold code, "|", then bold code again, and so on.
This should make it a heck of a lot easier to post Transponder readings, channel assignments, etc.! I know I used to try [ code ] tags and was always counting spaces.
:up Thanks, Scott!
Testing
WHIO | 7 | 7007
WDTN | 2 | 7002
WKEF | 22 | 7022
