Hi all,
I've got a Satwork 3688 with SG2100 motor drive, works fine. Since it was sunny last week, on a whim I pulled the cable off of the Ku dish and stuck it on my old C-band BUD that's been sitting idle for years. Damned if it didn't work also! Started looking around and decided maybe I'd like to have a play with FTA on C-band. But I'd rather not have to manually swap the coax between the Ku dish and the BUD each time. My question: how can I add a switch? The 3688 is Diseqc 1.2. BUT...does my Diseqc SG2100 mess up the ability to also use a switch? Can I put a 2-way Diseqc switch AFTER the SG2100 and BEFORE the Ku LNB, and then run another cable to the BUD's LNB? I.e. one input of switch is from Ku, other input is from BUD, and output goes into house. I believe this is the purpose of the switch but I don't know if it can be used on a system that also has the motor drive. Alternatively, my user manual for the 3688 also says it can handle a 22K switch and a 12V switch - are these a different method of controlling a switch not involving the Diseqc?
And before it is pointed out, yes, I realize that my Satwork isn't going to drive my BUD positioner. I'll have to dig out my old 36V BUD drive from the attic, or leave the BUD locked on one satellite.
thanks
SS
thanks
SS
