using FSS LNB
the FSS frequencies seem an exact match for standard Ku (what you miss is the small extra range on a universal Ku).
only channel I know that you will miss is Cubavision international
See thread on this forum
http://www.satelliteguys.us/archive/index.php/t-28099.html
basic DVB Free to Air system will pick up the Pas 9 (58w) satellite where the "Cubavision International" TV channel is. (IF YOU HAVE A LINE OF SIGHT TO THE SATELLITE) The trick is to use a " Universal " LNBF for this channel
also in this thread:
its a good idea to also buy a standard Ku LNBF at the same time as they come in handy for pointing the dish if you or your installer use a signal meter.
see this thread for reason you want this kind of LNB
http://67.19.94.137/showthread.php?t=23602
If you only have universal LNB then you would have to use the on screen signal meter on the TV, remember you are looking for quality only signal strength means nothing.
Dish size and satellite broadcast footprint.
also Not using RG6 cable may also affect this quality at your location.
recommendatiions of 90 cm or 120 cm (1.2m) size dishes have been made.
Minimal size is 30 inches for most FTA
see
http://67.19.94.137/showthread.php?t=41912
You can also get a .3 db low noise LNB for pulling in weaker signals as stated in this same thread above
Also you should know I am a newbie and just started learning about this technology.
Would like to hear about your testing of these myself.
