still can't get started
deadstick
34
I got a new setup and can't seem to get it up and running. I just got through tearing the whole dish assembly down and checking everything and putting it back up. I have a coolsat 4000 pro receiver with a 32 (or 33) inch dish and a rotor sat hh90 motor. The directions are not entirely clear to me as I don't know most of the terms. I am in Odessa, TX. 79762. I set the motor to 32, which I believe is my latitude, and the dish to 40 according to what I discerned in the instructions. I pointed the dish due south but I have no idea which satellite is due south of me or how to find out. Please help point me to the next step. Thanks..
Odessa, TX 79762
Latitude 31° 53.340'N Longitude 102° 21.288'W
Sat Name Sat Lng Az(t) Az(m) El Skew
Intelsat 901 18.0W 93.0 84.6 -3.9 -58.0
Intelsat 603 20.0W 94.1 85.7 -2.2 -57.9
NSS 7 22.0W 95.1 86.7 -0.5 -57.7
Intelsat 905 24.5W 96.5 88.1 1.6 -57.5
Intelsat 907 27.5W 98.1 89.8 4.1 -57.2
Hispasat 1C/1D 30.0W 99.5 91.2 6.3 -56.9
Intelsat 801 31.5W 100.4 92.0 7.5 -56.6
Intelsat 903 34.5W 102.1 93.8 10.1 -56.1
AMC 12 & Telstar 11 37.5W 103.9 95.5 12.7 -55.5
NSS 806 40.5W 105.8 97.4 15.2 -54.8
PAS 6B/3R 43.0W 107.4 99.0 17.3 -54.1
PAS 1R 45.0W 108.7 100.3 19.0 -53.5
Intelsat 705 50.0W 112.2 103.8 23.2 -51.8
Intelsat 707 53.0W 114.4 106.0 25.7 -50.6
Intelsat 805 55.5W 116.3 108.0 27.8 -49.5
PAS 9 58.0W 118.4 110.0 29.8 -48.3
Amazonas 61.0W 121.0 112.6 32.2 -46.7
EchoStar 3 & Rainbow 1 61.5W 121.4 113.0 32.6 -46.4
Estrela do Sul 1 63.0W 122.8 114.4 33.8 -45.5
Brasilsat B2 65.0W 124.7 116.3 35.4 -44.3
Brasilsat B1 70.0W 129.8 121.4 39.1 -40.7
Nahuel 1 & AMC 6 72.0W 132.1 123.7 40.5 -39.1
DirecTV 5 72.5W 132.6 124.2 40.9 -38.7
SBS 6 74.0W 134.4 126.0 41.9 -37.4
AMC 5 79.0W 140.7 132.4 45.1 -32.5
Nimiq 2 82.0W 144.9 136.5 46.8 -29.2
AMC 9 83.0W 146.4 138.0 47.4 -28.0
Brasilsat B3 84.0W 147.9 139.5 47.9 -26.8
AMC 16 85.0W 149.4 141.0 48.4 -25.6
AMC 3 87.0W 152.5 144.2 49.3 -23.1
Intelsat Americas 8 89.0W 155.8 147.4 50.1 -20.4
Galaxy 11/Nimiq1 91.0W 159.2 150.8 50.9 -17.6
Brasilsat B4 92.0W 160.9 152.5 51.2 -16.1
Telstar 6 93.0W 162.7 154.3 51.5 -14.6
Galaxy 3C 95.0W 166.3 157.9 52.0 -11.6
Intelsat Americas 5 97.0W 169.9 161.6 52.4 -8.5
Galaxy 4R 99.0W 173.7 165.3 52.7 -5.4
AMC 4 101.0W 177.4 169.1 52.8 -2.2
AMC 1 103.0W 181.2 172.8 52.9 1.0
AMC 15 105.0W 185.0 176.6 52.8 4.2
Anik F1 107.3W 189.3 180.9 52.5 7.9
DirecTV 6 & EchoStar 6/8 110.0W 194.3 185.9 52.0 12.1
Anik F2 111.1W 196.2 187.9 51.7 13.7
Solidaridad 2 113.0W 199.6 191.2 51.1 16.5
SatMex 5 116.8W 206.0 197.6 49.7 21.8
EchoStar 7 & DirecTV 7S 119.0W 209.5 201.1 48.7 24.7
EchoStar 9/Intelsat Americas 13 121.0W 212.6 204.2 47.7 27.2
Galaxy 10R 123.0W 215.5 207.1 46.7 29.5
Galaxy 12 125.0W 218.3 209.9 45.5 31.8
Galaxy 13/Horizons 1 127.0W 221.0 212.6 44.3 33.8
Intelsat Americas 7 129.0W 223.5 215.1 43.0 35.8
AMC 11 131.0W 226.0 217.6 41.7 37.6
Galaxy 1R 133.0W 228.3 219.9 40.3 39.3
AMC 10 135.0W 230.5 222.1 38.9 40.9
AMC 7 137.0W 232.6 224.2 37.4 42.4
AMC 8 139.0W 234.6 226.2 35.9 43.8
EchoStar 1/2 148.0W 242.7 234.3 28.8 49.0
Satellite Finder is (c) Copyright 2004, P. Lutus
I would use the below TP./channel
DFreq: 12100 MHz(V) SR : 20.000 Msps
If I may assume the one in red (amc 1) is the satellite due south of me, how do I use this information to get a signal. Is there a becon?
Well yes, you enter the above Frequency/polarity/Symbol rate and watch for signal QUALITY as you aim the dish. I do not have the Coolsat. It would be a GREAT idea to have a channel already stored on your receiver before you add the motor. I would remove the motor and find/store the above channel without it for now.
What is the "above Frequency/polarity/Symbol rate" ? Does it have something to do with the "Sat Lng Az(t) Az(m) El Skew" ?
No.
DFreq: 12100 MHz (frequency)
(V) (Polarity)
SR : 20.000 Msps (Symbol rate)
These values have to be entered in the antenna set up screen on the receiver, then aim the dish and watch the TV for signal QUALITY.
I'll give it a try in the morning. Thanks for the help. By the way, where do you get these values? Are they different for each satellite?
Search google for Lyngsat or Satcodx, they have data on sats. Values differ for each channel. Is best to mount dish to pole to start, log a channel first then worry about motor. You'll be twisting the dish around a bit, may tend to slide down pole. Find short (2") piece of plastic pipe about pole dia, cut plastic length wise, wrap around pole, secure with hose clamp. Be paitent, takes a bit of time to find first sat.
Morning folks. Gotta say thanks again for all the help. I am encouraged now to keep trying! If I remove motor and go with pole alone, do I set the dish to my latitude? Also, I don't know what it means to "log a channel" . I really am as dumb as I look.
Use the above information, all the angles for the satellites are there, just pick any satellite and use the angles given. Enter a LIVE TP./Channel then aim the dish until you see signal QUALITY.
I bought a new mast, very heavy. Got it all lined up and level again, this time without the motor. Set everything and checked it twice and nothing. I even cut new coaxial cable to make sure. No matter what I do I get signal at 15. Even with the cable out, I get 15! I give up! I've been making fine adjustments for the last three days and never got signal quality better (or worse) than 15. I am beginning to think my brand new receiver is a lemon. By the way, I know ya'll have tried to help but what does "Enter a LIVE TP./Channel" mean?
It means to use a LIVE (an actual verified in use/on air/broadcasting) channel that we can see right the second you are working to setup (enter it manually if needed). That way you can be assured you are looking for something that is really there.
For AMC1 (103.0w) I would try to use the Pentagon Channel @ 12100 V - 20000-3/4
If you are not using a motor, you will have to use a different dish elevation (the actual elevation), which you can find here:
http://www.lyngsat.com/tracker/america.html
Select the satellite you're trying to hit and it will give you a map. Its a little difficult since the map is very small, but use your mouse to point and click on the map to where you live, and the site will return your dish elevation and azimuth (compass) settings (for use without a motor).
In the list of satellites I gave you for your area it lists both true and magnetic positions......
That answers my other question about the az(t) and az(m)! On the receiver there is a place to enter lnb type. Choices are single, universal, and ocs. Which do I put in? I have a coolsat brand ku-lnbf model cs-lnbl rf:11.70/12.20Ghz if:950/1450Mhz lo:10.75Ghz gain:60db noise figure:0.6db . Also, the lnb has two cable ports. Am I supposed to hook both up?
Standard vs Universal ?
PBS AC3 and coolsat 4000 pro
