I just wanted to share my experience with this dish and those sats on the title. I acctually found that this dish is way better ( I mean way better) than a regular chinese made or similar flimpsy ones like Fortec Star or Ariza not only due to its superior construction but also the quality of the signals it gets. due to its dual LNB (quad output) with the 4 degree offset it worked great on 79W/83W combination and I manage to get all 24/7 signals (there are not much anyways) but also the news feed that usually pop up on this birds in the afternoons usually. Even on rainy days I had no issue with KTEL neither with RTV or the NBC bar screen.
But what cut my attention was when I aimed it to Hispasat not only I was able to get everything but only 1 narrow low power signal but the fact that the difference in S/N ratio with the fixed Ariza 80 cm perfectly tuned was only 2.2 Db's!!!! yet as per the birdog the Q reading was 0 (but it had a lock obviously). For the Cuban mux S/N were 8.6 dB for the 60E and 0 Q but with the Ariza 80 cm it was 10.8 dB S/N but a whooping 85 and more Q on the birdog. Amazinly the Constellation map was very similar for both dishes and on the SA (very limited screen) they looked similar as well , but despite the big difference in Q readings , the S/N levels are only 2.2 appart and even on overcast skies the small eliptical 60E dish holds those signal quite well including incredibly the 8PSK Uruguayan mux. Will test more under rainy conditions tomorrow with Hispasat to compare both but I got the feeling that the 60E will stand to its Channel Master name reputation. I have not been able to find more info on the 60E dish in regards of its efficiency and more importantly its radiation pattern as I think it holds the answer to the low 0 Q readings with high impressive 8.6 dB S/N ratio values for those power Cuban, Spanish,and Overon muxes(the Arab one was weaker).
Of course the debate is open for anyone to share some ideas about this "mistery" if you will , lol.
Readings with the AZBOX Prem+ are in the 70's for the strongest ones with the Ariza 80 cm but in the 55's for the SC 60E Dish yet dont think that just rain will kill the 60E signal.
