I have a sw44 outside with 2 coax coming in to a dual tuner. Can I split that to run to another dual tuner
If the OP really has a sw 44 it takes two lines for a dual tuner, separators won't workYep.
Technically you can run 4 dual tuner receuvers. I'm assuming you're referring to a 222 or 722. But with a seperator or triplexor on back of receiver you only need one line instead of two.
But if you want to run two cables from switch to the two inputs on receiver that's fine too. Just more cable and can only have two receivers instead of 4
Yea my bad, I read it quick and was thinking dpp44 switch but it says sw44 and those haven't been used in like 15+ years lol.If the OP really has a sw 44 it takes two lines for a dual tuner, separators won't work
