OK. I'm still dense, so I'd better check to make certain that I understand this. I'll use 110.0 West as my example.
I understand that the magnitude of the distance allows for satellites to appear to be at the same position while they actually are not. Does this mean that the satellites are just a couple of miles apart in longitude (Which I am thinking is no.), or latitude? (I'm thinking yes) Latitude seems to be what the sat charts show.
One of my problems in understanding is this: I thought that for a geosynchronous orbit, the satellite would have to be exactly on the equator. At 110 degrees, six satellites are parked. If they are 3 miles apart (in latitude), that would equal 18 miles of separation. Maybe this isn't really much considering the earths size? Maybe the satellite is able to correct itself in orbit? Maybe I'm completely off in my reasoning?
How far apart (in actual miles) would two satellites be that are 2 degrees apart?
Like Galaxy 10R at 123.0 W and Galaxy 12 at 125.0 degrees West? I'm going to try to figure this out. I'm certain that I'll come up with the wrong answer.
Thanks for putting up with stupid questions
Edit - Using a 2 * 3.14 * Radius = C and assuming a radius of 22,500 miles I get an answer of 785 miles (for distance between satellites with 2 degrees separation.) If this is correct, I guess that 18 or so miles wouldn't be much of anything.
