Which is the best direction to go?
Slave my SV360 Elite to my DSR922 or slave my DSR922 to the SV360 Elite?
I am currently using my Uniden analog receiver (without the VCRS module) as the dish mover. I have the lnb going directly into Tuner 1 of the SV360. I have a coaxial cable going from the Uniden to a small television (turned on, of course) to be able to see which satellite I am selecting. Simple, huh?
I have only C-band on an 8 foot mesh dish. No Ku.
If I should slave the SV360 to the DSR922, how do I connect the two together?
For example: Do I use the Tuner 1 in for the LNB? Loop Tuner 1 out to Tuner 2 IN with a coaxial cable? Then connect Tuner 2 out to the IN on the DSR922?
Or if I should slave the DSR922 to the SV360, how are those connections made?
Simple, clear directions would be greatly appreciated.
Now, as far as what would be shown on the television screen I have to explain myself first before I ask the question. It used to be that when I used only the analog receiver (before FTA) and I wanted to change satellites, I would get a blue screen on the television when I pressed CALL to select a satellite. I would select the satellite then press CALL again. The dish moved to the satellite. The blue screen disappeared and the channel showed up.
When I want to watch a program on the SV360, do I have to turn on the DSR922 to select the satellite in order to move the dish? It's my understanding that the DSR922 is on all the time even when it is off. Or will the SV360 tell the DSR922 to move the satellite?
If I do, does the choose satellite screen on the DSR922 override whatever is being viewed on the television from the SV360?
If I am watching the DSR922 and change satellites, will I find that the SV360 will have changed satellites, too?
Is a High frequency splitter recommended or does this fit into the equation? If so, which receiver gets the power pass port?
If there are any questions I've missed, ah....just go ahead and answer the questions I've missed! lol.
Thanks.
Thanks.
