Signal Splitter
We only sell diode steering splitters. I have used a wide variety of splitters in this way for years that I usually just pull one out of my collection. Maybe another member could suggest a brand or model that they are using? I remember using Eagle Aspen brand, but don't recall the model.
Brian,
I just wanted to let you know that I am using a spare receiver to control the dish with the 5th cable line. Everything works great at this time. I will keep looking for a splitter to use, but this will work until I can find one. I am ready for the winter cold!! That was my goal to get this up and working!:)
I also wanted you and others to know that after purchasing your two GEOSATpro SL2 Bullet LNBF's, 4x4 switch, and laying total of five cables runs, I am VERY HAPPY :) of the Signal and Quality I now have. I am getting 83* at S90/95Q as well as all my satellites! You were right to not use any Diseqc or single LNBF's. Thanks for all you have done for me!
Now Working
:) SATELLITEAV
Brian, :up
I am trying something different with my system. I am not using a splitter. Last night I installed a (ECODA) EC-2111 Switch in place of the splitter. To my surprise, it works and works very well! :) So far there is no back feed and no over heating on lines or switch's. I can use all (4) of my reciveres at the same time. I only lost 10 points power for one satellite. It just went down to S60/Q75 on 83*. I was getting S90/Q95. The picture is still great. I can live with that! Thought maybe I could place an inline amp for 83* later if I just want to have my higher numbers. I will let you know if there are any bad changes. My wiring for the switch is below.
I hooked the master Rceiver cable to Lnb A
I hooked Motor cable to Lnb B
I hooked Rec to REC 4 (Master) to 4X4 Switch
Keystone7
zero position on SG2100
Openbox reciever //sathawk thanks sadoun
