Signal Loss
Good info.
With one correction ...
While it is true that all English programming today on 119 are comprised of SD locals on spotbeams.
It is not true that the satellite there is only "used for spotbeams so most tps. will be low."
The 119W satellite (or "D7S") has seven CONUS beam tps., which should read in the 90s to sometimes 100.
Tps. 22, 24, 26, 27, 28, 30, and 32.
Its four spotbeam tps., 23, 25, 29, and 31, may read low to 0 for the OP however.
True, but I didn't say only, just that it was used for sd spot beams.
Reverse Band 3 LNB No signal 99 & 103
Raycom Stations Warn of Potential DirecTV Blackout
