Signal Levels - What to expect
bchandler02
237
69
Ever since I had my HWS installed, it seems like I have more rain cutout. They did replace my dish/LNB combo when installing it as it was suspected at one point that the LNB was bad (which it later wasn't). I had two dishes, 1 at 110/119 and another at 129, and had aligned them as perfectly as possible to help prevent rain fade. Now I just have 1 dish.
I suspect that when the new dish was installed, it was not aligned perfectly and this is what is causing my excessive rain cutouts. So, the question is - what signal levels should I expect on a clear sunny day for each bird? What transponders are better to test on, if any? I'm going to manually adjust it and want to make sure I get it as perfect as possible.
I'm in OKC (73160) if that helps, and system is a 1H/1J on 110/119/129.
Thanks!
Hopper OTA dongle is great receiver
Dish Wifi Adapter Kit Dual Band 802.11N
