Will sd channels look better on a hd reciever then a sd reciever?
As one said, Its mostly your TV.
But no a 722 is not going to have Better SD PQ then say a 625.
Its the same.
The 211k is a good receiver, If you want it get it.
You can turn it into a DVR for about $100-150.
Dish Networks Mpeg 2 SD is 540x480 Western ArcIf you check into the HDTV ratings from Consumer Reports there are some HDTVs with excellent ratings for viewing SD programming and others not so excellent.
I believe it was The Krell that told me(correct me if I'm wrong Krell) that Dishnetwork's SD is 544x480,where DirecTV's is 480x480.I can see a difference.
After having DirecTV's SD programming for 3 years I can say Dish's SD is a better picture.I already thought this when I had Dish before but switching back and forth confirmed it.
I have noticed that when a programmer goes HD with a channel that my SD picture looks like it's a downrezzed HD picture with the definition a little clearer and the colors are deeper.
I have Dish's 625(connected-S-Video) and my RPTV screen is 50" that has been calibrated and cleaned every 4 years.
I have an old 4700 connected via an s-video cable and a 622 connected via a hdmi to dvi cable to the same tv. The picture on the 4700 connection has by far a more brilliant color picture. Since neither the 622 nor the 4700 allow you to adjust picture directly, you are subject to the picture adjustments of your tv. At the same picture adjustment the 622 seems washed out compared to the 4700. I can go in and adjust the picture settings and get a better picture for the 622 than is capable from the 4700. However, it really makes the 4700 overcolored. Since the 4700 allows us to play some Dish interactive games at a higher interactive speed than the 622 is capable of, we like to keep it connected. So I have tried to adjust the tv to make the 622 and 4700 pictures enjoyable.
For your intended use, you probably will be able to adjust the tv's picture settings to be optimized for the new receiver and have it look as good or better than your current receiver.
Again others may please correct me. But on many Dish SD channels, I believe Dish only gets the HD version of the channel and downscales it for SD receivers. This looks particularly silly when the provider is sending a widescreen picture, which is most of the time! Dish letterboxes the signal for SDTVs, and also tells the receiver this SD channel is 4:3. This results in the addition of pillarboxes by the receiver since I have it connected to my widescreen HDTV. Black bands all around. My wife does this to us all the time since she likes to channel surf using the Up arrow button, and stops when she sees a program she likes.I have noticed that when a programmer goes HD with a channel that my SD picture looks like it's a downrezzed HD picture with the definition a little clearer and the colors are deeper.
I had a 501 and when I bought a Sylvania 32" HDTV, I fiddled and fiddled and eventually got one channel to look good. But it seemed like the available adjustments were only suitable for one channel, and I had to fiddle some more with every channel. I returned that set and bought a Vizio which out of the box did a much better job of upscaling than the Sylvania. I was able to adjust it and leave it that way for all channels received, so we were happy until I upgraded the 501 to a 612. My Westinghouse 42", however, looked great on my 625 without any adjustments whatsoever. (I replaced that with a 722.) All adjustments were done so long ago I no longer remember what I did.Which picture adjustments would need to change to get a better picture on my hdtv? I have my 508 hooked up with s-video.
I doubt that Dish does any HD-to-SD conversion for SD channels--its done by the stations themselves.... But on many Dish SD channels, I believe Dish only gets the HD version of the channel and downscales it for SD receivers. This looks particularly silly when the provider is sending a widescreen picture, which is most of the time! Dish letterboxes the signal for SDTVs, and also tells the receiver this SD channel is 4:3. This results in the addition of pillarboxes by the receiver since I have it connected to my widescreen HDTV. Black bands all around. My wife does this to us all the time since she likes to channel surf using the Up arrow button, and stops when she sees a program she likes.
