well I got mine (and some other stuff I ordered)
I hooked it up to the extra line from the T90 so we have 8 LNB's set up
First thoughts (I played with it while dinner was cooking)
-The interface is interesting but I figured out once you go into "scan" you can go from there. You can move to set the different LNB's/satellites up by pressing a button
-Meter seems to be a little more "legit" than other receivers
-changing TP info is easy to do along with deleting TP's
-when you do a scan, it does a NIT (network) scan. This helped with IA5 (G25) as some of the Globecast TP's have changed. This figures it out
Bad things
-I HATE the volume thing. I wish there was a way to set it for all channels (max)
-If you have a standard LNB, the default LO is 11250 (????) so you have to set it to 10750 as you go along
Other notes..
-I did see it does have an option for "uncomitted" switches so maybe this will work with the 8x1 diseqc switch
-Picture on screen does look pretty clean
Bad things
Other notes..
