LNB resolved / lesson learned
When I first got my Satpros, I hooked to the first available LNB/dish/cable I could dig out of the tangled web that is my computer room.
Seemed to work, and I was pretty excited.
Was getting plenty of experience doing receiver setup, etc.
That night , several weeks ago, I lost all signals.
By testing with a cable from another LNB, I decided to abandon my first LNB/dish/cable, and move to something that worked.
I didn't troubleshot the problem.
And I was still getting good experience doing receiver configuration and setup, so it didn't really matter.
Last night I lost signal from the 2nd LNB and that's when I got suspicious.
After doing a full in-house test, I knew the problem had to be outside.
I went out with ladder, tools, and a spare LNB.
While pulling the vines off the cables going up to the roof, I discovered a broken connection.
I normally put 6' cables on all LNBs , then go to grounding blocks, then the main cable into the house.
The grounding blocks are under the eaves, out of the elements, and well protected.
Unfortunately, this particular setup was quite old, and the 6' stub was not up to the task.
I'd long sense converted to the proper water tight connectors for all other uses, but this one hadn't gotten swapped out.
It was a crimp-type, and had pulled out.
Guess the joke is on me.
Moral of the story?
Use the good stuff, even where it "won't matter"... 'cause it always does!
Moral of the story?
