1.Make sure you have 1k2 Ea 1k2Wa or Dpp500+ with a new 44 switch
2.Make sure you have two lines
(cable has to be 3Ghz)from the lnbf to the solo node.Cable between the node and the Hopper also has to be 3Ghz.
3.Connect the node,the host line goes to the Hopper the Client line goes to the Joey
4.Connect the Hopper and download the software and activate!!!!Downloading the software and activating takes about 20-25 min.Do not do anything with the Joye.You can take it out from the box but do not plug the power cable or the coax cable.
5.When the Hopper is activated you will see the screen with the option to watch live tv then you go to the other room and connect the Joye.It will take about 10 minutes to download and activate.
6.Next time do not sleep in the DNS training
and do not do any installs with 2 hoppers and 4 Joyes until you learn everything about the new system.
