Sat A, odd 13V, drops out sometimes
danxd
About a week ago, Sat A began to drop out. No warning or obvious sign of trouble. I live in So. Cal., so it's not weather.
Through research on this and other boards, I think it's the triple LNB. But I'd like to be sure before I buy a replacement. Because it might be the multiswitch.
Here's the weird part -
Testing sat signal when it drops, here is the result:
o = no signal
x = good signal
1 - 8 o x o o o x o x
9-16 o x o o o x o x
17-24 o x o o o x o x
25-32 o o o x o x o x
Any suggestions on how I isolate this problem? How to I check the triple LNB quality? How do I check the voltage on the multiswitch?
Any suggestions are appreciated.
If you have a phase 3 dish the LNB and multiswitch is one unit you will replace both if you replace the piece that screws to the arm on the dish.
Ready for HD in Ft Myers
NFL Week 12 SundayTicket/SuperfaN Sched
