Samsung RVU setup/review
rsoares28
71
Toronto
I recently purchased a Samsung UN32F5500 for my sons playroom. This TV is a 2013 model therefore RVU enabled so I was looking forward to seeing this setup in action. I loved the idea of just a TV hanging on the wall, no shelves, no a/v storage units and no receivers... Just like a picture frame.. Kinda the idea tv marketers pushed on us when flat screen TVs first arrived.
The only cables required are the power cord and Ethernet. Wifi works as well but I like the constant connection of a wired setup.. Now you must have a genie model receiver for this to work so a hr34 or hr44. I have a hr44 and it is connected to my network through a deca. I know the genie models have there own deca built in but I originally had an Hr24 and when I upgraded to the genie I left the cabling as is.
Upon powering up the Samsung it will take you through a setup sequence. For TV setup you only have the option of stb or OTA. Just to proceed I chose OTA and once it got to the channel scanning screen I cancelled the scan. Next it asks you to setup the smart hub (apps).
Once that is complete press the input button and all the options will show up across the top. The first two inputs are labeled TV (analog cable/OTA) and RVU directv living room ( what I named my hr44). When you select that input the familiar directv GUI shows up with instructions on how to add this TV.
At this point go to your genie, menu/settings/whole home/add client. You will be given a 4 digit pin #. Take that pin back to your RVU TV and you'll notice the screen changed, same directv GUI but now its asking for the pin #. Once entered a note will pop up asking you to call directv to add this location.
I called the 1800 # and the first person had no idea what I was taking about. I tried my best to explain but he kept asking me for a receiver id. He transferred me to tech support but I was hung up on during the transfer. I called back and got a new gentlemen who knew exactly what I wanted and completed the task in less than 5 mins.
He asked for the TVs manufacture and also the 4 digit pin. Once he added it to my account the TV screen changed, it was now asking me to name this location. I named it playroom. Next it asks if you want to copy all the settings from the genie, ( favs ch list etc) I agreed. Next it asks if you want to setup a new remote but I declined as the TVs remote works everything perfectly.
After the remote setup screen channel #100 pops up. The directv rep asked me to check a bunch of channels and all came in fine. The only thing I noticed is there is a minor 1 second video freeze when you change channels... Not at all a deal breaker but I'm trying to be as detailed as possible in this review.
In regards to the Samsung remote.. All the buttons work as intended. Ch up/down, direction pad and select button, guide. Pressing menu will still bring up the Samsung TVs menu. In order to access the directv menu you have to press the yellow coloured button. The recording list is accessed by pressing the blue coloured button.
Some extra notes.
-upon turning on the TV there is a 30sec wait for the TV to access the RVU server.
-There is still a $6 charge for adding the RVU TV.
Hope this was helpful. Don't hesitate to ask any questions.
Sent from my iPhone using Tapatalk - now Free
FYI, you can get a RC71 DIRECTV remote, program it with code 54000 and it will control your Samsung RVU client just like the RC71 on your HR44.
Does the Samsung remote this year have a skip fwd/back button, my 2012's remote doesn't have buttons that will do that, another reason for a RC71.
The F5500 models and above for 2013 are RVU enabled. The remote has ff/rew and skip. Skip if you press once ff/rew if you hold it
You said you could have used wireless, are you certain about that/
That model TV has built-in Wi-fi so that should be an alternative (note I didn't suggest it was optimal) to doing things wired.
My RVU-capableSamsung has built-in wifi also but if you try to set up RVU on wi-fi it tells you that you must have a wired connection. It's a limitation in the Samsung firmware. Hence my question....
?Have the same tv in my kitchen. Had the EXACT same experience trying to get it added to my account, right down the the hang up! Mine forces me to be connected with Ethernet and will not work over wifi. I splurged on the RC71 remote on amazon for $7 http://amzn.com/B00D96J8IM , although the samsung remote worked fine using solid signals conversion chart http://blog.solidsignal.com/content...for-your-RVU-Client-Find-the-buttons-you-need.
I have had it about a month and the only issue I have come across is that skip back doesn't work well but rewind does so its not much of an issue.
Wouldn't it be easier to say that you want to activate a "client" & give the pin number,& then when they ask for the model of your client,say Samsung RVU tv?
Some extra notes.
So after initial setup, in addition to the TV and it's own power cord the TV needs to have an Ethernet cord into the back of the TV?
That is the strongly recommended method (although Wi-fi may prove mostly workable).
When the first RVU TV's came out the speed was so slow that most opted to get a receiver instead of using the RVU in the TV. I am hoping that those times have changed, but its been so long since I heard anyone using RVU.
Most (all?) Samsung TVs do not as yet support wireless for RVU (although at least some Sony Tvs do).
But people have reported success by using a wireless CCK, the TV still thinks it is connected by wired ethernet
I am looking to get a "RVU-Ready" TV later today and have a room with only power outlets and want to see if this is an option.
I wouldn't plan on it. As texasbrit points out, you have to use some extra hardware (i.e. a Wi-fi gaming adapter or similar) that depends on how well your Wi-fi signal gets to the room and how busy the Wi-fi portion of your LAN might be.
The speed is ok.. From power button to first sight of video Takes about 15-20 secs. Ch chgs have a minor delay, nothing to complain about at all. Love where this is going.
Should get better with the 2014 model (H5500) samsungs as they now offer a quad core processors over the 2013 (F5500) which only offered dual core.
splitter
I got my own commercial
