My house is pre-wired with RG6u cable that has 2.25ghz on the cable. Will this present a problem for the hopper? Apologies if this has been discussed before.
I guess that's specific to the hopper. I have no problems with this rg6 with a 622 and 612.It would probably work but it is not standard to Dish who wants 3.0....
Just wondering. The hopper would be receiving the same signal from the Dish that the 622 receives, so why would I have a problem with rg6/u 2.25ghz?Yes, it is specific to the Hopper...
Probably 60-65 feet from the Dish to the node, then another 40 or so feet to the hopper location.If it is not a long run of 2.2 then it will be alright.
It's not the same signal from Dish to Hopper. It's the same signal from Dish to the Node.Just wondering. The hopper would be receiving the same signal from the Dish that the 622 receives, so why would I have a problem with rg6/u 2.25ghz?
If I understand correctly, you're saying only the rg6 from the node to the hopper would possibly need to be upgraded to the 3ghz rg6. Is that correct?It's not the same signal from Dish to Hopper. It's the same signal from Dish to the Node.
The signal from Node to the Hopper requires an additional 500mhz (plus headroom) of bandwidth to accommodate the 3rd tuner.
My Hopper works perfectly, for 3 years, on an RG6 cable that I ran 28 years ago. It is 100' long.My 20+ year old RG-6 works fine from node to Hopper in my bedroom.
That 2.5 ghz just means that is what the cable has been sweep tested to that frequency with a specified amount of loss. There is no specific reason that 3 ghz frequencies will not go through that cable, it has just not been certified to work at that level. There is a very good chance you will have zero problems with it.
YES they even get stuck working on Holidays.Fingers crossed.
The installer will be here in about an hour so we'll see then. Yes, they work on Sunday's.
If it works and makes his job easier, I bet the installer will have no problem with it.Fingers crossed.
Agreed. The working part is the key part. That all said, I guess it all depends on the QA tech in his area... I hear techs can fail for using pre-existing wallfishsIf it works and makes his job easier, I bet the installer will have no problem with it.
Update! The installer came and went, and everything works with the existing rg6. In fact, the only thing I'm having a bit of a problem with is my Denon 3802 Home Theatre receiver. I can adjust the volume and turn it off, but I can't as of yet get the remote to turn it on. I suppose I'll have to experiment with other codes.Fingers crossed.
We told you so!I can also confirm, despite Dish tech support's insistence to the contrary, that the EHD's from the 622 do indeed work with the hopper.
Yes, you did. If I had to rely solely on Dish support, I'd end up pretty frustrated. It's a good thing "Satellite Guys" is around.We told you so!
