Hopefully will start out as good as the Sathawk is now ( or better on hi bit rate feeds ) .  If that's the case, I'll probably buy another one.  Thanks for the input, Sadoun.
We will be getting a small qty of PVR800 in 2-4 weeks that will cover our backorder and any new orders until then. Currently we are out of stock.
A newer HD model may follow (i.e. PVR900) with the same features as the PVR800 except:
Estimated Introduction time: September 2010 (subject to change)
- No CI/CA
- No Scart connection (useless for USA)
- No ethernet connection (not needed for our target customers)
- Newer IR remote control
- Lower price
I just noticed that on the latest firmware the "ZOOM" button no longer functions to magnify the picture. It now acts like the "SAT" button on most other receivers to allow you to select the satellite using /\, \/, PG+, and PG- keys. This is quicker than the old way of going through all the intermediate satellites before getting to the one that you want.
...And now I see that the new remotes have a "SAT LIST" button. Guess that's why the change was made.
Does the Channel Editor work with the new "Motor" firmware?
I was doing a lot of editing of channels this weekend and realized how annoying it can be. As most of you have noticed everytime you edit channel names and you blindscan you loose the channel names you already changed. Gets a lot old with all the CH-1's and other weird names stored in the Sathawk. I'm used to the Fortec where it didn't overwrite everything. Even with the channel editor it doesn't really help much. Everytime you blindscan you're back to where you began.I doubt this annoying quirk will ever be fixed. Unless someone has figured a way around it? Blind
 I have just started to organize my listing and changing the names and now you have to tell me this.I like to blindscan when looking for new feeds!Unless there is some kind of solution then ill need to blindscan less.
 I have just started to organize my listing and changing the names and now you have to tell me this.I like to blindscan when looking for new feeds!Unless there is some kind of solution then ill need to blindscan less.http://cgi.ebay.com/SKY-SatHawk-800-PVR-HD-satellite-receiver-DVB-S2-CCcam-/220636987235?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item335efd3f63http://cgi.ebay.com/openbox-Solomend-HD-PVR-satellite-receiver-DVB-S2-1080P-/220636974594?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item335efd0e02Does anyone know how to make this box not to move the diseqc motor when browsing at the different satellites?
For example, when browsing the channel list, the motor moves to each satellite that the cursor passes on. I want the motor to move only when i select the channel not when i am just browsing on it. Any ideas?
Using the editor, on the channels that you don't want a scan to change, change the Service ID to "0". The scan will then not see those channels as part of the stream and will not overwrite them with new data.I was doing a lot of editing of channels this weekend and realized how annoying it can be. As most of you have noticed everytime you edit channel names and you blindscan you loose the channel names you already changed. Gets a lot old with all the CH-1's and other weird names stored in the Sathawk. I'm used to the Fortec where it didn't overwrite everything. Even with the channel editor it doesn't really help much. Everytime you blindscan you're back to where you began.I doubt this annoying quirk will ever be fixed. Unless someone has figured a way around it? Blind
