That means a DPP is able to dynamically swap frequency bands for Odd and Even. I was hoping the 2 separators on each end would work, but now don't think it will, unless the DP-34 itself could handle the dynamic frequency swap.
You're on the way to answering why that won't work. AFAIK, tp 31 from 119 and 110 are the same frequency, so forcing both on the same line would introduce interference problems that are avoided by 9° satellite separation and standard (legacy or DP) switching.SmityWhity said:Typing the previous post, I was thinking maybe using 2 DP Separators as if they were 2 diplexers might work, but I have a feeling it won't. Besides providing Odd and Even at the same time (DishPro bandstacking), it can provide Odd and Odd from two different satellites (DishPro Plus) at the same time.
I vote for (B). While DishPro utilizes band-stacker, I think of DPP as a band re-stacker. This early photo of the Separator shows tuner 2 gets the high band and tuner 1 gets the low band and sends power and commands. If both tuners want an odd tp, even from the same satellite, it would need to be translated to the upper band for tuner 2....I suspect when the DPP44 receives a certain command, it sends the requested signal for the second tuner down the same line by either offsetting the frequency, another bandstack, or multiplexing it. Then the DP Separator, separates it to the correct tuners.
