All I was saying was not to rule it out. Mdram, you can see how quickly this becomes a religious issue. I don't believe you would be dissatisfied with any receiver mentioned so far (now if someone says Bose...
) You will find fans and critics of all brands.
Any of the mentioned receivers should handle the required power level, assuming a reasonably efficient speaker. So you do need to think toward speakers here as that will make a big difference.
2 HDMI inputs is easy. Every receiver mentioned so far has 4-8 HDMI inputs. You might also want to consider the following features:
- upconversion of component/composite inputs. It allows one connection to the TV and one stop switching at the receiver.
- Audyssey calibration. Will use a microphone to give you an automatic basic setup of speaker levels, equalization and delays.
- variable resolution video output resolution (1080P, 1080i, 720P etc)
- HDMI 1.4 switching (futureproof for 3D and newer formats)
- THX certification
- Direct inputs (to handle decoding that comes in the future)
- Volume limiting (when you don't want to wake the kids)
- Input labels (so you know it is the bluRay and not VCR2)
