I have a 500GB external drive that I used on a 622 & a 211k for a year or 2 until the A/C adapter died. Because of that the data on the drive was corrupted. I had a 250 GB drive that I put in the enclosure and adapted a new A/C adapter and it worked fine. I took the original 500GB drive and was able to delete the partition and created a new ntfs partition and used it as a data drive. Well ultimately the 250 drive stopped working (another cheap chinese A/C adapter bit the dust!) So I mounted the original 500GB drive in a new enclosure, repartitioned it with ext3, and connected it first to a 211k which wouldn't format it (it recognized it and wanted to format but the format failed)so I tried it on a 722K still wouldn't format it. I removed the partition, the 722k still wouldn't format it. Partitioned it with ntfs but no go. Still the drive works fine as a data drive but Dish receivers won't have anything to do with. This really doesn't pose a problem for me but I am wondering why it is a drive which once worked fine with the Dish receivers, still works fine as a data drive but now won't work with the Dish receivers. Oh and I did run a surface scan and there were no errors were found and S.M.A.R.T. data is all OK also. So why is this.
Michael
Michael
